Ketti
Posted on - 06/18/2012
I can’t seem to access the NI-DAQmx. NET Help files from my Visual Studio 2010. I just got Measurement Studio 2010 for Visual Studio and I wanted to open the .NET/C# help files, but I can’t.
An error message tells me that it cannot be found.
Does anyone have a clue on how to solve this?
Thanks
Unable to Access The NI-DAQmx
If this is the first time it happened, try restarting your computer then try it again. If the problem continues, you should check if you already have acquired all the necessary specifications of the program you are using. To fully use the application, you must first meet its required specifications. To use National Instruments Measurement Studio support for Microsoft Visual Studio 2010, your computer must first be running with Windows Server 2003 R2 32-bit, Windows Server 2008 R2 64-bit, Windows XP 32-bit, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit.
You must also install Microsoft .NET Framework 4.0. And also, since you’ll be using it with Microsoft Visual Studio, your Microsoft Visual Studio 2010 should be in Professional, Premium, Ultimate, Visual C# Express [doesn’t support Microsoft Visual Studio Express edition], Visual Basic Express [doesn’t support Microsoft Visual Studio Express edition], and Visual Web Developer Express Edition.
For more information, you may visit NI Measurement Studio Development Packages for Visual Basic .NET.
