redchimes
Posted on - 06/19/2012
Configuration Wizard states that my running database is not 3.0 version and unable to continue, saying that database need to be upgraded to version 3.0 first.
Previously, I used a version 2.2.1 installed at this Pc, but I haven’t try to upgrade it. I need properset up. I assumed that I've already uninstalled version 2.2.in last month. I am free from Flow*.* or Netflow*.* tables in my database.
I am unable to access to the previous version (v3.0) of Netflow Analyzer.
Your Orion NTA database is not an Orion NTA 3.0 database.
Before upgrading to Orion NTA 3.1 you must install Orion NTA 3.0
Please update your current installation to Orion NTA version 3.0, and then return your upgrade..
Do you want to continue with this upgrade?
Help needed.
Unable To Access To Previous Version v3.0 of Netflow Analyzer
It seems that you are trying to upgrade your present version of SolarWinds Orion NetFlow Traffic Analyzer to version 3.1 while still using the older version which is below the required specification for upgrading the program.
As what the setup wizard says in the dialog box that you posted, your computer must first be running with SolarWinds Orion NetFlow Traffic Analyzer 3.0 before it can be successfully upgraded to SolarWinds Orion NetFlow Traffic Analyzer 3.1.
This means that you are really using the version that is lower than 3.0.
For the upgrade to push through, you need to install SolarWinds Orion NetFlow Traffic Analyzer 3.0 first. To download SolarWinds Orion NetFlow Traffic Analyzer 3.0, you may visit solarwinds — Unexpected Simplicity — Downloads.
When the download is complete, uninstall your present version of SolarWinds Orion NetFlow Traffic Analyzer then run the newly downloaded installer of SolarWinds Orion NetFlow Traffic Analyzer.
Just rerun the upgrade when the installation is complete.
