Unable to Access Question Writer Tracker
I am trying to login to Question Writer Tracker and publish a question but I am getting an error message that says:
"There was a problem connecting to the server. Check your internet connection and try again. "
My connection is working perfectly fine, and I can very well access other websites.
However, I am still receiving this error.
How can I fix this?
Best Answer by Michael B Rodgers
Answered By 0 points N/A #102380
Hello emily,
it seems like you are having difficulty in reaching the website's server and i think that is the problem. try reloading or refreshing the page until you can connect to the server. it is likely the traffic coming in to the website's server that might be causing the problem.
Answered By 45 points N/A #102381
Hello Emily,
It seems to me you are having a problem with Question Writer Tracker. This problem could arise if you have difficulty in reaching the server where you are trying to upload your question. You can try reloading the page if it does not work the reason could be the traffic coming into the server of this website. You can also check your internet options to make sure this uploading to this server is not blocked by your service provider. You can also flush your DNS and try loading the page again.
I hope this helps.
