Unable to adjust Microsoft project 2010 budget chart to print
I received a MS Project 2010 file (mpp) by email and I'm assigned to do two tasks, the first one is to preview and print the Microsoft project 2010 budget chart as a Gantt chart without table information on it, then I'll have to adjust the chart to print to A3 Paper size, what are the right steps I should follow to set the chart to print correctly?
Best Answer by Mueller Legette
Answered By 0 points N/A #179815
Hi Ava Larry,
You can do the shrink to fit function of your print option before printing the project that you are doing. To do that, follow these steps:
  1. On file menu click print and view page setup
  2. Look on the view tab and choose fit timescale on the end of the page
  3. Close them and return to the workload.
  4. Now go to the view menu of the MSProject 2010
  5. Lower the Timescale percentage and see the changes.
Answered By 0 points N/A #179814
Hi dear,
Thanks for asking the question.
I have easiest way of your problem.
You make changes in your print setup, such  as chart or calendar view.change your page orientation, scale
Paper size if you want to take print just click on view then click on page tab.if you want to change the setup of page
Click on portrait(vertical) or landscape.if you want change the page size.just click on the page size box.
For more details i am giving you a link.
https://support.office.com/en-us/article/Basic-tasks-in-Project-2010-13971a6b-bf00-47c8-a5b9-37c10fbc8eea?CorrelationId=61699e7f-31ca-4a53-a943-58e480df84fd&ui=en-US&rs=en-US&ad=US&ocmsassetID=HA101833929
I hope you will like this.
