anonymous
7060 points
Posted on - 12/11/2011
I have recently installed windows 8 in my machine but don’t know having problem with the machine as whenever I try to load windows 8 it just won’t load it and the screen keep freezing at that moment only. Is there anybody here having same problem with this operating system, I know as this is the windows 8 beta version but still this is something different problem, isn’t it? I have tried to search the solution for the same on internet but still haven’t find any yet and that’s the thing that made me confused as what shall I do next in order to get it work. Any suggestion for resolving this would be appreciated.
Unable to boot in to windows 8
The problems that are causing your recently installed windows 8 to continually freeze when you restart could be as result of the following:
The windows 8 being a beta version, it could be missing some important components that are required for its proper functionality, and therefore you will need to get the full version. Or you can choose to use windows 7, which I have not incidents of any malfunctioning when using it.
Or if the operating system was working just fine up to some point when it started to freeze when you load your system, then you can try running the system restore utility to restore the system to a time before it started freezing.
But bottom-line is that errors always exist in beta versions of applications and therefore when using them you should be ready to experience them.
Regards
Thompson Locker
