Hi everybody,
I have a Sony VAIO F1521ASN Laptop with pre-installed Windows 7 on it. Everything is working pretty well.
But only problem with Microsoft Office 2003. When I am creating a new document on it the hyperlinks are changing the color to green in the task pane. Even if I change the hyperlink color to blue it is again changing to green. I reinstalled the Microsoft Office. But still the hyperlink color is green.
Can somebody please give me solution to fix this problem? Thanks a lot in advance guys!
Unable to change the color of the hyperlink in Microsoft Office 2013
It is a hyperlink formatting problem.Â
You can format text, or a graphic, for a single hyperlink by selecting it and applying a new format.
Please follow these steps so that you can change the hyperlink style and format:
1. First, open the document that you want to modify.
2. On the Formatting toolbar, click the Style and Formating option.
3. From this step, you have two options:
3.a) You can change the appearance of hyperlinks by picking the formatting apply box and then right-clicking the Hyperlink style button and the clicking on Modify.
3.b) You an also change the appearance of the following hyperlinks by picking the formatting apply box and the right-clicking the FollowedHyperlink style, and the clicking on the Modify button.
4. Select whatever formatting option that you want, or just click Format, and the click the Font section to see more options that will help you format you hyperlink.
With these above mentioned steps you are able to change the color, style, font, anything related to hyperlinks.
