Unable to change setting in Microsoft Plus
Now this is the error message that I get whenever I try to change any settings in Microsoft Plus. I have a few themes in Microsoft Plus which I am trying to implement on one of my Windows XP machine and I am not able to do so.
Does anyone have any idea what can be done for this?
Catalog Error
An error occurred while processing the last operation.
Error code 8000FFFF – Catastrophic failure
The event log may contain additional troubleshooting information.
Answered By 0 points N/A #114702
This error code is a common code for Microsoft error. You may get this error from any other problem like windows update or install software. So don't worry about this. Microsoft already release kb article and tools fix this issue. Please download
MicrosoftFixit50202.msi. this small tool from download.microsoft.com. After download please install this tool after finish installation please restart your computer then scan with this tool.
If problem is not solved then please browse below Microsoft support link. And edit some registry by using regedit command from Start + RUN and write regedit.
https://support.microsoft.com/en-us/products/windows.
Hope you will get your solution now.
