I currently have Microsoft Office 2007 installed on my personal computer. I recently purchased Microsoft Office 2010 and tried installing it on my personal computer ,but was unable to complete the installation.
I get the following error message during the installation.
"Error 1406. Setup cannot write the value to the registry key."
Then the installation is canceled. Does anyone know what this error message means. I did uninstall Microsoft Office 2007 on my computer ,so there should be no conflicting registry entries.
I tried the installation several times using several installation medias, but still get the same error message.
I also restarted my computer several times, but it did not help.
Unable to complete Office 2010 Installation
Dear Christina Tate,
Set the permission for the group registration all subkeys that appear in the error message for total control. To do so,
Click Start, click Run, type regedit in the Open box and then click OK.
In Registry Editor, locate and click the subkey that appears in the error message.
In the Edit menu, click Permissions.
In group or user names, click around the world.
You must add the group if you are not available all. To do this, follow these steps:
With the permission of the Office of dialog box, click Add.
In the dialog box select users, computers, or groups, click Advanced.
In the dialog box select users, computers, or groups, click Find Now.
Under the name (RDN), click all over the world and then click OK.
In the dialog box select users, computers, or groups, click Ok.
In permissions for all, click to select the Full Control check box.
Click Ok and quite the registry editor.
I hope that this will work
If you receive an error message 1406: Setup cannot write the value to registry keys, it may be because one of the following:
Check whether you have sufficient permissions to modify sections of the registry needs to be done to take action.
Check whether the basic pattern of high levels of security applied Group Policy is applied to your computer and the basic pattern of high level security restricts access to the following file:
For Windows XP or Windows Server 2003
Office 2010
C:Documents and SettingsAll UsersApplication DataMicrosoftOfficeDataOpa14.da
Office 2007
C:Documents and SettingsAll UsersApplication DataMicrosoftOfficeDataOpa12.dat
For Windows Vista or Windows 7
Office 2010
C:UsersAll UsersMicrosoftOfficeDataOpa14.dat Office 2007
C:UsersAll UsersMicrosoftOfficeDataOpa12.da
If you cannot modify this file, users can not start an Office program on a computer.Opa12.dat Opa14.dat file and is specific hardware. In addition, these files are compiled during installation of Office.
To resolve this problem, use one of the ways below:
Method 1
Set permissions for the group Everyone in the registry subkeys that are listed in the error message to Full Control. Use the "Fix" then follow langak-steps described in the Knowledge Base.
Method 2
Disabling third-party applications
Method 3
Create a system to the status of a "clean boot", then run Office setup. This disabling third-party applications. Third-party applications are refused access to the registry subkey is no longer able to deny access.
