Unable to connect to ICQ login server.
I have just installed the latest version of Miranda. There were no problems during the installation.
I have installed it in default options. But when I try to change my icq status to "online" I receive error message "unable to connect icq login server. The server to which you are trying to connect does not exist. Check your spelling in options – network – icq (error 11001)"
I checked the options, but I really have no idea what to change:
Login server – login.icq.com
Port – 5190
I am not an IT specialist, and I do not know what does that mean, and the more so I do not know to what I need to be changed in the option. Any advice?
ICQ Error
The server to which you are trying to connect does not exist. Check your spelling in M->Options->Network->ICQ (error 11001)
