I am having a big problem with my windows longhorn.
Last day, I had just installed it with WiFi driver, but now, I am unable to connect to the internet. Whenever I try to connect, it gets connected successfully, but after that, it instantly gets disconnected showing an error message.
I have captured the error message and posted it below.
Generic Host Process for Win32 Service
Generic Host Process for Win32 Services has
encountered a problem and needs to close. We are sorry
for the inconvenience.
If you were in the middle of something, the information you were working on
might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to help us improve
Generic Host Process for Win32 Service. We will treat this report as
confidential and anonymous.
To see what data this report contains, click here
Send Report Don't Send
Please guide me how to fix this issue.
Kindest regards.
Unable to connect internet to Windows longhorn after installing wifi driver
I think your Wi-Fi application is somewhat incompatible with your operating system but I’m not that sure if this is really an incompatibility issue so you better check the proper documentations that come with your software. This type of error message is usually common to appear on incompatible programs. You should check again the “read me” file of the program or maybe visit its Help section by clicking it on its menu.
Check the system requirements of the program to better assess the problem and find a possible remedy if it’s still possible. Check your computer’s specifications if it meets the requirements of the application. You may also try reinstalling the software to have a new copy installed on your system. This clears your system from any corrupted files that affects the system.
Try to install the exact driver for the windows you are using also check the hardware for the software you are trying to use and make sure it is plugged in properly and working fine.
Smith Thompson
