Unable To Connect to Phone’s WiFi – HTC Thunderbolt
Hello techyv!
Hello techyv!
Hello Dear,
Here is the easiest solution for your WiFi networking system. As for a WiFi connection, you need a hotspot. Using some software, you can do this in a very easy way. Now, I’m telling something like it:
Connectify is the best software for establishing the WiFi networking. It routs the windows build in WiFi network card for sharing the online or available internet connection to home/ private network.
Using this software, you can
1. Start hotspot with desired name and password.
2. You can also share the internet of your liking.
3. You can also connect smartphones.
Hope, this will help you.
Notifications
