“Unable to connect to the server” in Chernclient.
Hello all,
I found a problem while using the Chernclient.
For the past 4 hours I tried to do whatever is available on the forum but nothing goes fruitful for me.
I keep getting this error message, popping up a few seconds after starting Chernclient.exe:
ChernClient main-server unavailable!
We were unable to connect the server. Please make sure you have a stable internet connection.
The sever might be experiencing some problems, do you wish to start the client anyway?
I hope someone can advice me what to do, I already tried fixing everything via all my internet security down completely etc. nothing goes to work.
So now I need some sort of help.
Thanks in advance.
Answered By 590495 points N/A #155521
I’ve tried going to its site but it seems that every visitor needs to sign-in or register in order to have a full access to the site that’s why I wasn’t able to go directly to it. If this is the first time it happened with your game client, why not try restarting your computer then try it again. If it’s only a bug in the previous process then a restart will do. But if still not and since it is an online game, try playing it again some other time or maybe after a couple of hours. Maybe the server is quite full since your game client is receiving a connection-related problem.
If you are trying to play it during peak hours, maybe this is the reason why you are having a hard time connecting to the server. Try some other time or maybe during off-peak hours to be sure that there is not much web traffic going on. For more information about this, you may visit Chernarus Life Ultimate *With Stats Save*.
