Unable to connect to SSIS service on machine
Hi Expert DBA’s,
When I try to connect to a Microsoft SQL server, I ended up with an error message. In addition, I got this error pop up when I try to connect to SSIS service on machine. The error says the error loading type library dll. I have attached the error image please do check the attachment and explain me to fix the problem. Thanks a lot.
Connect to Server
Cannot connect to
Additional information:
     Failed to retrieve data for this request. (Microsoft.SqlServer.SmoEnum)
          Connect to SSIS Service on machine……… failed:
            Error loading type library/DLL.
                  Connect to SSIS Service on machine……….failed:
