Unable to create new report after installing MS CRM 2011
Hi to all,
For the past few days, I am in the process of installing the MS CRM 2011, and as its pre requisite, I have installed the reporting server extensions. After installing it, I tried to create a new report, but could not succeed. Then, I tried to see the default views in CRM, but could not. On creating a new file, I got an error instead of the report wizard.
The screenshot of the error is as follows:
Microsoft Dynamics CRM: Reporting Error – Windows Internet Explorer
Reporting Error
Error occurred while fetching the data extension.
– Error Details: Error occurred while fetching the list of data extensions installed on the report server.
Try Again Close
The following log was determined by enabling the trace:
>MSCRM Error Report:
Error: Exception of type 'System.Web.HttpUnhandledException' was thrown.
Error Number: 0x8004831B
Error Message: Error occurred while fetching the list of data extensions installed on the report server.
Source File: Not available
Line Number: Not available
Request URL: http://server:5555/Orgname/crmreports/reportproperty.aspx
Stack Trace Info: [CrmException: Error occurred while fetching the list of data extensions installed on the report server.]
at Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.XrmExecuteInternal()
My application and database are running on 2 different servers in the same domain and I am running on SQL server 2008 SP2. The reporting services is being run using the domain server account and CRM services under network services.
Your suggestions are needed in this regard.
Kindly help me out in resolving the issue.
Waiting to hear from you soon.
Kindest regards.
