Joy de Leon
Posted on - 12/19/2011
I am encountering a fault with my Nero info. It says, "Unable to make an XML parser example. Please reinstall XML core services (MSXML) 4.0 SP2 or higher."
This error occurred when streaming either Nero or Nero Nonfat. I went to find any online has improved but I could not deed any. I am proven uninstalling and reinstalling Nero but I get the one misconception.
Anybody got the corresponding job? Please refrain.
Unable to Create XML Parser Error in Nero
Hello dear!
Whenever advrcntr.dll file become unregistered you will face this message.
So first of all you have to check if the file is placed at its location or not? Open your C drive then program filescommon filesAdvrCntr4AdvrCntr4.dll if you found it then it means you have this files but it is not registered .dll [dynamic link library] file.
Now you have to register this dll file manually. Please follow the instructions to register it.
[FOR 32-BIT MACHINES] STARTRUNREGSVR32 C:PROGRAM FILESCOMMON FILESNEROADVRCNTR4ADVRCNTR4.DLL and press ENTER
[FOR 64-BIT MACHINES] STARTRUNREGSVR32 C:PROGRAM FILES(x86)COMMON FILESNEROADVRCNTR4ADVRCNTR4.DLL and press ENTER
You will find a message of success, press OK on it.
Good Luck,
Your solution to my problem really helps. Thank you for helping me fix the problem about my Nero in my computer.
