Unable to delete MPASM Suite: Couldn’t Locate Build Tool
Hi to all,
I have a problem in deleting files mainly the MPASM suite. I have tried removing it a couple of times; however, I just can’t seem to do it. Below is the HTML code.
Language tool versions: mplib.exe v4.41
Tue Mar 27 19:02:52 2012
Clean: Deleting intermediary and output files.
Clean: Done.
Couldn't locate build tool. Check tool locations.
As you can see at the end part, it states “Couldn’t locate build tool. Check tool locations”. All I want is to remove a file and it is getting so annoying as I encounter this error.
Urgent help needed! Thank you very much for the time spent.
Cheers!
