Unable to delete Yahoo Add-ons on Firefox
I’m using a Mozilla Firefox browser. The Core Temp executable toolbar had appeared on one of the toolbars on my browser on top of it. I used the Core Temp executable so that any installer with connection to Yahoo will not sneaked into my browser. But the Core Temp toolbar doesn’t block the Yahoo add-ons. I tried to uninstall the Yahoo toolbars but I failed. It is still showing on my browser’s tab. I know that Yahoo is a safe program but I get annoyed from its existence especially on my browser. I really want to remove it on my browser. How can I stop it from appearing into my browser? Please I need your help as soon as possible.
Best Answer by lee hung
Answered By 75 points N/A #117033
Hallo Isabelle Jenkins,
I think you can also remove the tool bars from the control panel. Just access the control panel and from the add/remove programs option look for core temp executable temp tool bar from the list of files and then click on remove to uninstall it completely.
You can also hide the tool bar from the menu bar so that you cannot be able to view it, but note that doing so will not uninstall the tool bar program but only hide them. Just right click in the menu bar and then uncheck the tool bar that has the core executable temp as one of its tools.
Hope this helps.
__
Regards
Lee Hung
Answered By 0 points N/A #117034
You have to (re)install the yahoo toolbar from the yahoo site.  Once you have the full version, you will be able to remove it via extensions in firefox or the control panel.
