Unable to detect Battery in my Toshiba laptop
I have a Toshiba Satellite L655 Laptop and its battery is not getting charged after upgrade to Windows 8.
When I hover the mouse over battery icon, it says "No Battery is Detected". When I had Windows 7 the battery use to be detected, but after upgrade to Windows 8.1, it is no longer recognizes the battery.Surprisingly, I can take the AC power off and the laptop will run on the battery, but it still shows that the battery is not detected.
Is this a problem with compatibility or some driver missing issue? Thanks in advance for your help.
