Unable to disconnect drives planned on Windows XP
Hi
I am not able to disconnect some drives that are planned on a Win XP Pro workplace. I tried to remove the drive planning names because they were poorly outdated but without any success.
Need to solve this. Thanks in advance
Answered By 0 points N/A #104498
Viruses, worms , trojan stops disconnecting drives, USB and other devices in your computer. Make sure your antivirus is updated. Just update your antivirus and fully scanning it and completely removing unwanted viruses, worms and trojan will do the trick. If you cannot update your antivirus and cannot perform full scanning of your computer, your computer is severely loaded with viruses. I suggest you to:
1. Download a trusted anti spyware install it , update it and fully scan it.
2. Download a trusted anti malware install it , update it and fully scan it.
(NOTE: Make sure after fully scanning your computer that you remove all detected viruses.)
-Oriendo Cathon
