Unable to establish VPN help
Asked By 1220 points N/A Posted on -
I am using Cisco AnyConnect VPN Client, to connect to our corporate VPN connection. When I was about to connect  it fails to connect. An error message pops up that says, "unable to establish VPN connection".
First thing I did was, to check  my LAN connection.  It was connected, and as I refer to other computer, it can connect.
After much isolation on network connections and hardware aspects, I run out of  ideas to where I shall I look in to connect to the VPN.
Thank you all.
Answered By 0 points N/A #123647
Hi!
This method can solve the problem:
  • First of all open control panel.
  • Click on the network connection icon in the control panel. After clicking the list of dial up connection and other connection will be appears.
  • After you should click on create a new connection link on the left side of the windows. After clicking the welcome window will be appear.
  • Then click on the next button to start the wizard then choose connect to the network at my workplace from the given list and click next.
  • Then the other page will be appearing then you should click on the virtual private network connection and click next.
  • Then the computer asks the name of the VPN connection as a company name after giving the company name click on the next button.
  • After this choose the option on the public network on the screen and click next. The option will be default automatically dial this initial connection. This option is to be as default.  Otherwise select do not dial the initial connection option.
  • After this enter the name and the IP address of the VPN remote access server and click next button.
  • Then choose the option connection availability from the present screen then click next. The default option will be automatically set.
  • After this click on finish button to complete wizard. The new VPN connection information has been saved.
Hope it will help.
Thank You.
