Unable to export files from Light Wave 9.6 to Vue 7
I’m facing some problems when attempting to get obj and lwo files exported from Light Wave to open again in Vue as well as in Light Wave. I am created these objects in Lightwave 9.6 prior to exporting them as .obj files. I find that these files open without any issues in poser and in hexagon. But attempting to reopen them in either Light Wave or in Vue gives a distorted version of the image with dark seams on the exported object. I tried to work around this by exporting it from hexagon as an OBJ. And now when I try and open them in vue I get the following error message stating that the file could not be read. This workaround however removed the issues in reopening the image in Light Wave. I am hoping someone could suggest a method to enable me to work with exported objects in Vue. Thanking you for all the solutions in advance.
Image:
Error:
Vue 7 Complete
Unable to read file C:UsersRich-PotterDocumentsModelsFarmhousetrial3house1.obj.
Answered By 0 points N/A #184573
As far as I can remember, I’ve encountered this kind of problem before in Poser 4, I can’t show you pictures as I don’t have that software anymore but rest assured this procedure can help.
First, you had to cut the front polygon then paste it back without merging the points before you can export them as obj. this way you’ll produced a straight edge corner. You can also do this vice-versa.
