Unable to find the MS Word document
Hi all,
I am using Dell Inspiron 15 with Windows 8 on it. I am using Microsoft Outlook for sending/receiving mails.
Today I got a mail with a word document attachment. I have opened the attachment and modified lot of content and then saved and closed it. However, I have not saved in a different location even though I just opened it from mail directly. Now, I couldn't locate that file in the system.
Did anybody faced this problem? How can I get the modified document? Will it be present anywhere in the system? Please help. Thanks a lot in advance, guys!
Answered By 0 points N/A #193200
When using outlook, the downloaded content will likely go to the downloads folder. There are two ways of finding this folder. One, you can look in your favorites section. If the downloads folder is not available there, enter this URL C:UsersXXXDownloads. Put your computer name in place of XXX. Once in the downloads page, right click on the page and select sort. Then, select date modified and Descending. Your file will be on the top of the page
