There is a tricky problem with my Lenovo laptop idea-pad A1-07, it has in-built power control widget options but are is not responding satisfactorily. The problem starts when I performed up-gradation on the operating system, after that I have reinstalled all the drivers successfully but unable to fix the issues of the power widget Lenovo laptop idea-pad A1-07.
Unable to fix the issues of power widget Lenovo idea-pad A1-07
Hi Lindsey,
               Most of the time touch screen unresponsiveness can be caused by a screen protector if you did not install it properly chances are it can unresponsive. To isolate further you can try these following options: Power off the computer and then check if it responds after restart, you can also do a reset and then turn back on computer. You can also try to recalibrate the screen by turning off A1, press and hold power button and then wait for the tablet to vibrate.
