James Craig
40 points
Posted on - 03/18/2013
Hi Guys,
I installed NEMO Media Player Plus in my Samsung Galaxy Duos though Google Play Store. It is an excellent player, but I need options like equalizer and more, so I tried to format Nemo Player but was unable to do so. Please advice on how to format the player.
Thanks,
James Craig
Unable to format Nemo Player
Nemo is stored in the Random Access Memory popularly known as ROM.I would advice you to do a hard reset and ensure that you return your tablet to the initial setting that made by the manufacturer. You should also ensure that you have backed up everything to your SD card. Should rebooting not work visit your seller and negotiate for possible replacement if your warranty still exists.
Good luck.
