Unable to generate an isometric drawing from p3d isogen
Hi friends,
I have recently been trying to generate an isometric drawing from p3d isogen, but I could not succeed. Each time while trying to generate the drawing, I get an error message on my screen. The screenshot of the error is attached below:
[Error: 32] Unknown Error in PISOGEN
I uninstalled the software and then reinstalled it again, but still, I failed to solve the problem.
I can't find another way out. I have searched a lot of forums, but couldn't find a solution.
Kindly guide me to resolve the problem.
Your ideas are most welcome.
Regards.
Answered By 590495 points N/A #142200
If this is the first time this happened when using ISOGEN, try restarting your computer then try it again.
If still nothing happened, try reinstalling the program to restore it to its default configuration and fix any corrupted files that may be present in the system.
Uninstall ISOGEN then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics test on your machine, use disk utility applications like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. Install the program again then check if this fixes the problem.
You may also try downloading its installer again. To download ISOGEN, please visit Intergraph – Global Network Partner.
