Unable to get back the Skype history
Posted on - 07/06/2014
I am using Lenovo Thinkpad T410 laptop with Windows 7 on it. I was using Skype with different Skype id and changed it recently.
I wanted to remove the unwanted temporary data related to the old Skype names. To do that I run the command %AppData% and in that went into Skype directory. Then I removed the folder with the old Skype name and my present folder thinking that it is temporary data only. But, unfortunately it cleared all my Skype history.
Why it is not able to restore the history, even after keeping the update folder Back? Please help.
