fredy32
Posted on - 09/13/2011
Hi
This is a debian Linux problem i have this time. Most of the daemons do not run, displaying the error to the console.
For example, look at what gives sshd error when I try to login
What is the reason for these errors? Â unable to handle kernel paging request at 0000000000000ffff
How can I fix these errors?
Unable to handle kernel paging request
Most of the time errors in the operating system are caused by an incomplete installation of an application, a driver error, a support application that was accidentally uninstalled, a file component of the operating system was accidentally got deleted, a hardware failure just like in an input/output (I/O) error caused by a failing hard drive.
To check the integrity of the hard drive, run any disk utility application to diagnose it physically including its contents.
If the damage is severe where running any application is already impossible, remove the hard drive and attach it to another computer and check it there.
If there is no problem with the disk drive, formatting your hard drive and installing a fresh copy of the operating system might fix the problem.
