Error on importing .vsd file using Mapping Visio Architect
Hi all,
I have created a .vsd file using mapping Visio architect and then publish its template. After that, I have tried to import it into repository/folder, but its throwing below error.I have even applied service pack 4 but the problem persist. Please suggest.
Error at (file C:InformaticaPowerCenter8.6.1clientMappingTemplatetest1.xml, line 3, char 52 ): Unknown element 'Graph'.
Error at (file C:InformaticaPowerCenter8.6.1clientMappingTemplatetest1.xml, line 3, char 52 ): Attribute 'Name' is not declared for element 'Graph'.
Error at (file C:InformaticaPowerCenter8.6.1clientMappingTemplatetest1.xml, line 3, char 52 ): Attribute 'Description' is not declared for element 'Graph'.
Error at (file C:InformaticaPowerCenter8.6.1clientMappingTemplatetest1.xml, line 3, char 52 ): Attribute 'UItype' is not declared for element 'Graph'.
Error at (file C:InformaticaPowerCenter8.6.1clientMappingTemplatetest1.xml, line 3, char 52 ): Attribute 'DlgSize' is not declared for element 'Graph'.
Error encountered while Parsing file.
Teri.
