I bought Adobe Creative Suite CS5 Design Standard then installed it on my PC with OS X 10.7.1. I started using it along with Illustrator and Photoshop and everything works fine. But the problem started the next time I started the computer. The program could not initialize the font menu. I am stuck with 90% and have 302 fonts on the computer. How can I fix this? Please help me.
lee hung
75 points
Unable to initialize font menu in Adobe CS5
Hallo Kylie,
Are there any updates that you recently installed on your computer that could be of Adobe Creative Suit CS5 Application? If there are any then they are the ones that are bringing the problems that you are currently experiencing; either they came with compatibility issues or some other problem.
I will suggest that you take back the system to a previous time before you started experiencing the problems. You can do that by executing the system restore utility, which you can access by going to start and then type "system restore" without the quotes in the blank search field and then press enter. Choose the restore point and the click OK. Wait for the process to finish and then check if the problem has been solved.
__
Regards
Lee Hung
