Unable to install Autodesk design review 2012
today I tried to install Autodesk design review 2012 in my system but when I started the setup the following error popped up. Can anyone tell how to resolve this issue?
Autodesk Design Review 2012 Microsoft C++ 2008 SP1 re distributed is required to continue with the installation. Please visit Microsoft download site to retrieve the distributed package.
Answered By 5 points N/A #138751
Hi Willie,
Before you can install Autodesk Design Review 2012, you should first install Microsoft C++ 2008 SP1 redistributed depending on what operating system you are using.
Download http://www.microsoft.com/en-us/download/details.aspx?id=29 for a 32bit Windows Operating System
Download http://www.microsoft.com/en-us/download/details.aspx?id=2092 for 64bit Windows Operating System.
After installing Microsoft C++ 2008 SP1 redistributed, try to install again the Autodesk Design Review 2012 and check if the error still occur.
Hope it helps,
Korber Owen
