Cohen Allen
10 points
Posted on - 07/26/2012
I downloaded a game, but for some reason, I was unable to install it.
The game I got was the darkest-dawn-setup.zip.
I used the CRC tool and the zip file is fine, but when I click "Unzip now…", the following message appears instantly.
WCS Setup 1.0.2.7795 ZIP Check & UnZip 1……
UnZip done
result : UnZip has FAILED!
time : 0 sec.
rc : 9
OK
I tried 7zip and seems a little better it decompresses darkest-dawn-setup.zip OK, but when I click darkest-dawn-setup.exe, the following message appears about a quarter of a way through the install.
Wing Commander Saga
Operation in progress
Please wait while Wing Commander Saga ks being processed.
C:UsersojsDownloadsWC Darkest Dawn Disk0003.tiz
Error 23 while opening this file:
Data error (cyclic redundancy check).
OK Cancel
I would appreciate any help with this.
Thanking you.
dacha893
Unable to install game ‘darkest-dawn-setup.zip’ after downloading it
It happened to me that game in 7zip too big then it is unable to unpack when you pack it look good but unpacking it isn't good find another download.
I think you just have to download the file again and hope that the file or the installer will work on your next download attempt. If after downloading it again it still has a problem with the installer file, try downloading it from a different website.
You can try to download it from the other affiliated sites. Below is the list of external mirror sites where you can download Wing Commander Saga: The Darkest Dawn:
You may also visit Wing Commander Saga | The Darkest Dawn is Cleared for Launch of the game’s official website.
