Unable to install Microsoft Office 2010
Asked By 7060 points N/A Posted on -
Why does this error "Setup cannot find the required setup controller file. Either there was a network error, and error reading from the CD, DVD, or other installation media, or a problem with the package you downloaded."
Pop up during the installation of Microsoft office 2010
Best Answer by Pallasigue Stabins
Answered By 0 points N/A #82862
Hi
The set up process sometimes make such problem.
The message "Setup cannot find the required setup controller file. Either there was a network error and error reading from the CD, DVD, or other installation media, or a problem with the package you downloaded" Is a compatibility issue that can be fixed. The windows you are using is not compatible with office 2010.
You should change the configuration of your computer. The least configuration is XP SP3. The VISTA & Windows 7 are perfect for running office 2010. So you should divert to windows 7 or Vista.
I hope this helps you.
Answered By 0 points N/A #82863
You have to check that whether the office source engine is running or not.
Solution 1: Click on START then on RUN type “services.msc” and on the window check for the office engine source (if it is not running then right click on it and choose START to enable it)
Solution 2: Use repair option to fix the issue automatically. (Click START > All programs > Add/Remove programs> select Office 2010 and click on Repair.)
Answered By 10 points N/A #82865
Hello Anonymous
It is a simple error and have many way to solve this problem. Here you can see many good techniques but my recommendation visit another Techyv post where you will get more techniques to fix this issue.
CANNOT INSTALL MS OFFICE 2010
