I have been trying to install Microsoft Office for Mac 2011, but I've been trying for few times and always failed with an error.
I posted the screenshot of the error that I am receiving.
I am running Mac OS X Server 10.5.8 with 2GHz PowerPC G5, 2.5GB DDR SDRAM.
How can I install it without getting stuck with this error message?
Error:
Install MS Office for Mac 2011
Software Requirement
This software requires an Intel-based Macintosh computer.
Close
Unable to install MS Office for Mac 2011
Hello Love,
That problem may occur if the processor in your computer does not meet the MS Office 2011 for mac minimum system requirements. MS Office for MAC 2011 needs an intel based processor. You can perform solutions below:
Quit all applications and close window. You need to quit all applications to be able to begin office for mac 2011.To quit an application, select the application on the toolbar (top), and then select Quit. If you cannot quit an application or do not know how, hold down the Command and Option keys, and then press Esc on your keyboard. Select the application in the "Force Quit Application" window, and then select Force Quit. Click Force Quit to quit the application.
Determine the processor type. go to APPLE MENU and select ABOUT THIS MAC. Note the processor type that is listed. If the processor is not an Intel processor, Office for Mac 2011 will not be installed. For information about upgrading the hardware, please contact Apple support.
Attached in this solution is image which can be helpful to solve your problem.
