Unable to install a plugin with Excel
Hello Whiz,
I am facing problem, which is completely new to me. When I try to install a plugin with Excel, I ended up with an error message. I tried to uninstall the plugin and then tried to reinstall the plugin again but it result the same error message. I do not understand whether the process is right or wrong. Please tell me the right way to install the plugin. Thanks for your help.
Disabled Items
The items listed below were because they prevented Excel from functioning correctly.
Please note that you may have to restart Excel these changes to take place.
Select the ones you wish to re-enable,
Addin: powerpivot for excel (Microsoft.analysisservices.mcdeler.fieldlist.vstolocal)
Answered By points N/A #170584
MS Excel comes with the ability of working with various add-ons, making any task to its user easier through those add-ons. But sometimes they don’t function properly and this one is not different than that. The add-on was disabled and so you’re unable to use it in future.
First, remove the add-on. To do this,
  1. Open Excel.
  2. Go to “File” tab >> Options.
  3. Select “Add-Ins” from the left pane.
  4. In the “Manage” box, choose “Excel Add-ins” >> click “Go”.
  5. Find out the problematic add-in, select it and press “Remove”.
If you were a hardcore user of the add-in, you have to get the latest one that doesn’t make such issue. After you’ve removed the add-in, you can install PowerPivot again from this page. Download and install it again.
No more problem for sure.
