Ava larry
10 points
Posted on - 12/21/2012
Hi to everyone,
Windows protect application launch error. This error is saying about launching file error, unable to launch application. What can be the main reason why the application cannot be launch? I have to run the Windows protect application to detect and avoid some malicious ware software in the computer registry, as an IT administrator I have to take good care of almost 30 computers in our business industry. I need your help.
Your suggestion is very much welcome.
Unable to launch the Windows Protect application
Hi there user:
I see that you’re really doing your best to take care of your unit. But still these annoying errors popped-up. You’re an IT Administrator so you should be aware that the error for launching a file is not (only) because of malicious ware we acquire on-line. The application or software could be damaged with improper installation or use. And the most instances for this are incompatibility issue. Check the version you're using if it meets the system requirements of your Windows.
Thanks for posting here at techyv.com
