Ashly Cruz
Posted on - 10/14/2011
Friends,
My dialer program generates following error messages during operation.
It shows that it is not finding catalog. I don't know why because I never changed its default setting or it's registry entries.
How can the problem be solved?
Call Logging
Unable to load catalog
Program terminated.
OK
Thanks,
Ashly
Unable to load catalog …
The solution of your this problem is also with some of my know users. These users had restricted pc and the “hfw” file was read only. If you should change the ntfs permission and than I sure it will work properly. So I suggest you also check the ntfs permission on your pc.
One another way of solution is like that, you should right click on the call logger and go to properties then go to compatibility, after it click on the run this program in compatibility mode than choose the OS you running on your PC. So if you running windows 7 than please choose Service Pack 3.
