Unable to load configuration information
Hello Whizzes,
When I try to retrieve the COM class factory for component with CLSID, I got this error message. The error says it is unable to load configuration information. How do I fix the problem without any reinstallation? Hunting for solution, please help me. Your help is really great. Thanks a lot.
Error
Unable to load configuration information. Retrieving the COM class factory for component with CLSID
{69c3e4bb-acc2-41f0-85d6-403c53A38D} failed to the following error: 80040154.
Answered By 590495 points N/A #168769
The problem here is that you did not mention the name of the application. The easiest way to learn what the error number in the message means is to search it on the web. This will display all possible errors with the same error number. But the problem if you do this is that it will not direct you to the same application or to your application since it will search for almost any error with the same value regardless of the program’s name.
In your case, since reinstalling is not an option for you, try closing the application, restart your computer and run the application again. See if this works. If not, you should check again the specifications of the program to verify if it is compatible with your operating system. If you downloaded the application, visit the site again where it is downloaded and check its system requirements.
Another way is to upgrade it to the latest version. It will help you fix the problem especially if the version you have has issues with your operating system.
