Hi to all,
I have recently bought 2 laptops, which are the same. I installed windows 7 home premium 64 bit on one system and windows XP professional on the other.
I actually wanted to migrate a Virtual PC from one system to another. So, on the laptop with windows 7, I installed the VM player and migrated the virtual pc from another system to this laptop. I started the virtual pc and everything worked well.
My problem started when I copied the installed virtual pc from the first laptop to the laptop with windows XP and the virtual pc could not be started.
When I tried to start the virtual pc from this laptop, I got an error on my screen. The screenshot of the error is as follows:
VMPlayer internal Monitor Error
If you have any information, please help me out. I can't find as to where I am making a mistake.
Waiting for your helpful feedback.
Regards.
Greengoo
Unable to migrate a Virtual PC from one laptop to another
From what I can see your problem is the operating system. Windows 7 can work with files created on win XP while win XP cant work with files created on win 7.
I used to have the same problem with win XP and win 98. My advice would be to try creating virtual PC on win 7 laptop by running the program as in win XP.
Another thing that might be causing this problem is the system version(are both systems 64 bit or not). .
I hope this helps.
When you encounter this issue: Gather analysis data. To read more, observe Accumulating analysis data for VMware merchandise file a new assistance ask for using VMware Service and also take note this kind of KB write-up IDENTIFICATION inside the issue description.
To read more, observe Submitting a new Service Ask for inside my VMware as well as The Way to Distribute a new Service Ask for.  Â
Notice: If you're able to recreate the challenge and also a person already owning a debug check, abide by this action inside the mistake communication to run a new debug check and also update your own assistance ask for using this data.
Regards.
