Unable to modify the specified Application
Asked By 190 points N/A Posted on -
I added a security group to the existing  AppV Application. I did it by the AppV Management console.
Before the process completed I got the following error message.
Unexpected error occurred.
Unable to modify the specified Application. Please report the following error code to your system administrator.
Error code: 0000B004.
Any idea?
Best Answer by Waall Mike
Answered By 5 points N/A #147167
Hi Joey Keen,
This is another common problem from windows os. There are two common reason may occur the error. They are,
  1. Database log for transaction reached to the max size.
  2. The log containing partition don’t have enough space.
To resolve this you can visit the below link of Microsoft:
Hope you will get better result. Wish you Good luck.
Answered By 270 points N/A #197745
Hello there Joel,
This has been a known issue for this app and windows have worked around the resolution for this. You need to download and install its hotfix/update and this issue will be gone for good.
Details regarding this upgrade can be found in Microsoft's Website
The ugpage can be downloaded from here. Make sure you choose the right language for you
Hope this help your problem.
Waall Mike
