adeleon
Posted on - 12/14/2011
My Operating System is Windows XP 64-Bit. I am not able to mount any image with ‘ImDisk’ as every time I tried, it gives me an error message stating that, ‘ImDisk Virtual Disk Driver loading error. It is not able to load as it has been blocked’. Please guide me to fix the issue. I will be thankful for all the help.
Unable to Mount Image with ImDisk
Well, that may a problem due to the application that you are using to mount the image, or it could be caused by the images that you are trying to mount, and therefore you will need to examine both situations. For the image itself you will need to check and make sure that it is in the format that is supported by the application that you are using to mount the image. Check the file extension that the image is in, and then check the file extensions that are supported by the application and then make sure that the format is among those that are supported. In case the problem is with the application, then it could have malfunctioned, due to some problem like the registry keys being corrupt or missing. And therefore you will need to run a registry fix program to rectify issues with registry entries, or you may need to reinstall the whole program.
-Clair Charles
adeleon
The problem is in the application and I run the registry fix program to correct it. And also reinstalled the program. After that it worked smoothly.
