Unable to obtain connection with SQL Server
I have posted a screenshot of the error I got while I am applying a local administrator account to set up XenDesktop. I run the installation on a Win 2008 R2 Enterprise machine. I have yet to connect the server to a domain. I have an SQL Server 2008 R2 located on the exterior of the domain, and I would be keen on using that server for the XenDesktop Database.
When I connect the XenDesktop5 server to the domain, I could not obtain a connection to the SQL server, since my Xendesktop 5 server is linked to the domain and the SQL server is not. I would greatly appreciate any instruction you could give on how to join to an SQL server on the exterior of the domain. Also, is it necessary to join the server of the XenDesktop with the domain before initiating? My profound gratitude for any help I receive.
MmcSnapin.dll
MMC has detected an error in a snap-in and will unload it.
– Report this error to Microsoft, and then shut down MMC
– Unload the snap-in and continue running
OK
