I am not able to open my ACDSee Photo Manager.
I was about to try to remove and reinstall the program in order to fix it but I remember that I have bulks of categorized files in it which could possibly be messed up.
So I just did a system restore and Microsoft update has been installed. Now when I am trying to open ACDSee, I get the same error.
I need someone who could figure out what is wrong with my system.
Thank you.
Unable to open ACDSee Photo Manager
First, uninstall the ACDSee From Windows XP. Now, Click the Start button. Click RUN. Now Type regedit in the text box and press enter. The Regedit program will open.
Now click the Edit Menu > Click Find. Type ACDee and click find next. Delete the information of ACDSee. Now exit Regedit. Now Install ACDSee again. It will work fine. In case it don’t start, then delete the ACDSee folder then do the mentioned method and install the ACDee again.
For Windows 7, do the Regedit process. Right click the main setup file of ACDSee and click Run as Administrator then complete the setup. Again, if the ACDsee don’t start, then delete the ACDSee folder then try the mentioned method and install the ACDee again.
Regards
Crawly Math
