Any Hill
30 points
Posted on - 10/29/2012
There is an error opening my sample law firm workflow. I am using windows 7 64 bit operating system and encoded those files in a Microsoft word document application. After a few minutes I restarted my computer and go downstairs to get something to eat and when I get back, I opened my laptop and get an error stating unable to open file. Please do help me, those files are very important.
Waiting for your support.
Unable to open files error in encoding MS Word document file
Well Any Hill,
It may occur too much reason. It is very difficult to suggest you a single solution.
I want to suggest you that copy those files and take it to another PC, Laptop or Tab and try to open the files using same version of Office program. If your laptop’s office corrupts then your problem is already solved. If not, then you may try to open those file by using word pad.
Thanks and hope you can get out of this problem.
Hi Any,
This is an issue that can be very hard to make suggestions with your issue since it can be caused by many factors. One of which is virus, which can be unlikely if you are updating your security software all the time and schedule virus scan. What I can recommend is to save your document on each opportunity that you have.
