Unable to open files from QuickBooks Pro
I am using Windows 98, but it is not connected to the Internet. My files in Quickbook Pro starting 1/1/09 up to present were lost. I used the restoration system, but I did not used back up since I don't have any. I decided to start it in new company, and every files was successfully exported, but sad to note that upon opening the files, I can't open it, and it said “C;QbooksSWPre.Qbw” is not QuickBooks data file or it is damaged(-5). I've tried it over and over again, but still it doesn't work. Please, help me to fix this problem. Thank you so much.
Answered By 80 points N/A #100654
Hello Deo,
You can't open files from quicbooks pro because the file that you are oprning can only be open or locateed in read-only folder network. Or in the machine that hosting the file,  only single user mode file is open. To be able to fix the problem, please follow the steps below:
  • Choose the Quickbook file menu
  • Choose close company
  • Select open or restore an existing file on the no company open window
  • Choose open company file .qbw or .qba
  • Hit the next button
  • From the company file list, choose the company file
  • Check mark the box beside open file in uder mode
  • Hot the open button
  • You can now log in as your normally do
You can also visit the link below for more information:
https://community.intuit.com/quickbooks-desktop
-Zorian
