Unable to open Interactive Decision Tree
The following error message appears when I click the Interactive property in the SAS® Enterprise Minerâ„¢ Decision Tree node. You can see the whole error image below. I also get the same exception when try to run the predecessors to this node and update the path. I am unable to resolve this problem so I need your assistance to fix this issue. Thanks.
Decision Tree data set is missing
Exception
Unable to open Interactive Decision Tree. The Decision tree data set is missing. Please make sure you have run the predecessors to this node and update the path.
Answered By 5 points N/A #171557
Hello Colleen!
I think that you're having that kind of error because your flow is consist of Control Point node right before the Decision Tree node so to solve your problem you have to remove the Control Point and the Decision Tree node then replace them with the new node. You can now launch the Control Point and connect the Decision tree node by selecting the "Interactive property" that can be found in the Decision Tree node.
