Unable to perform a system restore
I am getting an error message :
"System Restore did not complete successfully, Your computer's files and settings were not changed.
Ferdie,
I got the same problem some time ago and the same error exception as you are saying , I overcome this problem with two things , try those , I hope you will also overcome your problem as I did:
I hope these 2 suggestions will help you to overcome with your problem.
Andy Bogard
Hello Ferdie,
Uninstall your Antivirus and perform a system restore. This should probably fix the issue.
If this does not do it then try to restore the system in safe mode.
Uninstalling a program:
Go to Start –> Control Panel –> Uninstall a program.
Choose the program to uninstall by double clicking it.
Starting System in safe mode:
Restart your system, Press F8 before Windows logo. Then select safe mode.
Firstly, I’d suggest you to uninstall the Antivirus program and try to perform a system restore and check if that fixes the issue.Â
If the above steps do not help, try doing a system restore from safe mode and check if that works fine.
Let me know if this helps!
