I have purchased genuine copies of games like Black ops, Arma 2, Dayz, BF3 and BF4 for my Sony Vaio Z Series.
When me and my friend wanted to play together being on the same server, it is not allowing us. But when we play separately, we are able to do so. None of the games we own, allowing us both at the same time. We both are using the same network using separate Ethernet cables.
What is the cause of this issue? Is there any setting I have not done to allow more than one person to play the game?
Unable to play games together on the same network
Hi Matt, Basically IP addresses supplied by your service provider are given by default. So I just assume that either your LAN or your friends’ must be accessible through the internet, or being able to provide what is call port forwarding. It is a common thing nowadays that several online gamers to simultaneously play in the internet from the same residence and somehow inaccessible in your case. Try this next time you have a session. When your game starts,go to your Start menu, then Network, create a workgroup, press Windows and the Break keys which will bring up the System window. From there you can see your workgroup.
