I am doing a research on some websites. And there are certain websites that comprises with some important information that I need for printing. But when I print those information, the left border do not show the full width of the printed file by an inch or less. How can I customize this setting so I can print the entire page correctly? Thanks.
Predator
Unable to print a document correctly
You can do this:-
1 Click on file menu of your browser.
2 Click on page setup option of that menu.
3 A page setup option window has open.
4 Click on “format and option” tab.
5 Click right check mark on “Shrink to fit Page Width” option.
6 Click on ok button.
7 Click on print preview in file menu and see how page will print.
You can also do this:-
1 In format & Options Tab Uncheck the checkmark in “Shrink to fit Page Width.
2 Sat Scale in percentage you want. Firstly set it 50% and see in print preview that how’s it would be print.
3 If it is not appropriate then set appropriate percentage in this option and click on ok.
The printing would be fine
The web page you are printing is being printed badly as a result of it being too large and therefore not able to fit in the current specified margins that you have set, which should probably be the A4 paper size margins that are default margins. You will need to change that.
I will suggest that you try using the procedures below:
First try changing the paper specification in the printer dialog box to another layout, like the web page layout, from the default A4 paper size layout and see it the printed page will come out properly.
You can also try copying the information that you want to print from the web page to a word document, and then customize it properly and then you can print like a normal word document.
Regards
Thompson Locker
