Unable to read file or wont relink
Asked By 7060 points N/A Posted on -
I have U lead 11. Having part edited a video when I go back to recover it for further editing I get a message that it is unable to read the file or it takes me to a relink file when it says that all items have not been relinked and all I get is a background color section and the original transitions.
Any advice?
Answered By 15 points N/A #82621
I have read your problem and a best solution for your problem which I will recommend you is,
When you create video with "32-bit RGB" AVI, or "File: Export Video Overlay", that kind of AVI is used to do video overlay, so COOL 3D Production Studio won't render the background in this mode. That's why you won't see the background in the video preview window. If you want to keep the background, or use another data type, please use"24-bit RGB" AVI instead.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
