tylor green
400 points
Posted on - 10/26/2011
I am running Windows 7 on my two computers. Both are using Outlook 2010 as my personal email tool. I can use Outlook 2010 without problems on the first machine. But on the second machine, I was unable to read the subject lines on the Junk folder. Is there a setting that I can copy from the first machine in order to run Outlook on the second machine correctly? Please help. Thanks.
Unable to read subject lines in Outlook 2010
Hi Tylor Green,
You might have not installed the Outlook 2010 correctly on the second machine. Have it uninstall and install again. Anyway, did you check the free space memory on your second computer? Might as well its one of the problems you might have overlooked. Then after ensuring the free memory, does your Second Computer has an Operating System compatible with Outlook 2010? If not, choose the old version for the reason that the advance Outlook Express needs a higher processor.
Hope this might help you,
Thanks,
jennifer08
The problem may have occurred due to an incomplete installation of the Outlook. May be some of the installation files did not copy fully. The other problem may be due to available memory space. Check the system requirements for installation of the Outlook.
If your system is compatible, remove the Outlook program from your computer by using the Add/Remove program option in Control Panel and then install the program again. If the problem persists, change the version to a lower version of Outlook.
Thank you.
